philipkuhn
Posted: 04 Nov 2016, 09:49 |
I'm Philip from Kathu, Nothern Cape. I bought one of the best cars in SA. It does not look good at first, but there is potential. When you hit OPEL KADETT 200TS on GOOGLE, you will find a pic of this specific car when it was still very pretty.
| Attachments: |
_________________ Regards Philip Kuhn 0824155625 philipskuhn@gmail.com
| Topic moved BACK to "Projects" |
philipkuhn
Posted: 04 Nov 2016, 10:08 |
This is the find. The car is good, f28 gearbox, engine is striped with most of the parts already bought. But I will need help finding some cosmetics. I need a 1. std TS airbox 2. that plastic TURBO-intake cover. Please contact me if anyone knows where I can find this in South Africa.
| Attachments: |
sterlingesterhuizen
Posted: 04 Nov 2016, 10:53 |
| Cams, ITB's, Headjob, Management |
Joined: 09 Jul 2008, 11:59 Posts: 2991 Location: Kimberley
Damnit Good luck with the project
_________________ Hers:Opel Corsa Chill 1.3 His: Are you kidding me???? When married it states "What is yours is mine what is MINE is MINE!!!! Ours: Chevrolet Cruze 1.6L
Rebellious
Posted: 06 Nov 2016, 14:31 |
Joined: 21 Aug 2007, 14:57 Posts: 21995 Location: /\/¯¯¯¯¯\/\
Wow!
_________________ ▪█─────█▪
Klonkie
Posted: 07 Nov 2016, 07:25 |
Ou kry sommer 'n by-nes ook! My Opel maak BUZZ!
Good luck buddy!!
_________________ 2007 Opel Corsa Utility 1.4 2022 Toyota Corolla HB 1.2T 2024 Toyota C-HR 1.2T
Exes: 2015 Ford Ecosport 1.5 2014 Ford Focus ST 2.0T 2014 Opel Corsa OPC Nürburgring 1.6T 2005 Opel Corsa OPC 1.6T 2008 Volkswagen Golf GTi 2.0T 2005 Ford Territory TX 4.0 2004 Citroën C2 VTR 1.4 2001 Ford Fiesta Zetec-S 1.6 1998 Kia Sportage 2.0 1995 Fiat Uno Beat 1.4
philipkuhn
Posted: 11 Nov 2016, 16:16 |
Ekt hulp nodig. Volgens part no. verkil top-gasket van IS en TS engine? kan iemand vir my se, hoe dit van mekaar verskil. daar is nie TS gasket beskikbaar. Hoe nou gemaak?
sterlingesterhuizen
Posted: 11 Nov 2016, 16:38 |
philipkuhn wrote: Ekt hulp nodig. Volgens part no. verkil top-gasket van IS en TS engine? kan iemand vir my se, hoe dit van mekaar verskil. daar is nie TS gasket beskikbaar. Hoe nou gemaak? 200is is a 8 valve The ts is a 16valve You would have to ask for a 94/95 200ie head gasket or from a superboss, monza 200 cd.
philipkuhn
Posted: 14 Nov 2016, 16:10 |
thank you Ghostc20let. Im going forward!!
| Attachments: |
Posted: 15 Nov 2016, 13:15 |
Wow, great find!
philipkuhn
Posted: 16 Nov 2016, 13:16 |
I'm looking for this back panel to weld in. Please contact me if anybody got something that can help me. or have a better idea how to fix this.
| Attachments: |
philipkuhn
Posted: 28 Nov 2016, 07:54 |
Goeie naweek gewees. ekt a engine stand gebou en die motor gehang!! Alles lyk grand!!
| Attachments: |
philipkuhn
Posted: 28 Nov 2016, 07:56 |
Daarsy. nou kan ek begin bou. Al die machine werk is gedoen.
| Attachments: |
cyberpuppy
Posted: 28 Nov 2016, 10:48 |
| Filter, Exhaust & Branch |
Meneer, maak daai engine stand se basis 'n bietjie wyer jong! Dit maak my nervous.
_________________ 2007 Subaru Forester XT 197kW and 380Nm of home-cooked, GTI embarrassing tuning. With a little help from Powerflow ex: 2005 Coupe 168kW 350Nm From Evo Performance
philipkuhn
Posted: 28 Nov 2016, 11:37 |
philipkuhn wrote: Daarsy. nou kan ek begin bou. Al die machine werk is gedoen. My kar pas nie eers in my garage, space is baie limmeted. dis hoekom hy soo lyk. maar dit is baie stewig.
philipkuhn
Posted: 30 Nov 2016, 07:28 |
this Weekend I had help from a expert to do the assembly. I want it done perfectly. this motor must do 300 000k's and more!! Cleaned all the parts first.
| Attachments: |
philipkuhn
Posted: 30 Nov 2016, 12:18 |
THE GEARBOSS
| Attachments: |
sterlingesterhuizen
Posted: 30 Nov 2016, 14:08 |
Hoendertande
KadettGSi
Posted: 01 Dec 2016, 16:34 |
| Upgraded to a Flatbed Filter |
Nice project. Are you running standard bore still? Your build is making me miss mine on the road.
philipkuhn
Posted: 02 Dec 2016, 07:33 |
KadettGSi wrote: Nice project. Are you running standard bore still? Your build is making me miss mine on the road. Car has 187 000km's on the clock. Its 0.25 bigger pistons. Car still has allot of work on still!! the body work, worries me allot. In Kathu its not easy to find parts. Thanx for the interest. I see your PP. Nice TS!!
philipkuhn
Posted: 02 Dec 2016, 07:36 |
check what I found!! 310x260mm K&N
| Attachments: |
