 Post Posted: 24 Nov 2011, 10:25
Hey all
As requested by Jay-C.
Pls note that this not my tutorial as you will see in the pics.
Well, Here we go:
First off remove the storage bin near the ignition (below the lightswitch)
To do this, it's easiest to reach around the back and press the two tabs in on the top!
Now remove the two screws at the bottom of the lower panel. Pull gently from the bottom, and this panel can be placed in a safe place.
Next remove the screw from the underside of the steering wheel
Using a thin slotted screwdriver, undo the two clips on the front, on either side of the wheel centre
lift off the top cover
remove the two silver screws from either side of the steering wheel (just in front of the stalks)
Drop your adjustment handle and undo the screw on the front, and slide the handle off to leave the L shaped bar. Push the bar back home into the bottom of the wheel.
remove the base of the steering column cover
Now it's time to remove the housing:
Undo the two screws at the bottom
and the one at the top
pulling the top forward, lift the housing out. this is sometimes a bit tight, but it will come out.
All you have in front of you now is the clocks. remove the two screws at the bottom, lift the clip at the top centre and pull them straight out towards you.
On the back you will see four small twist out bulb holders. The bottom centre one is for your mileage readout (odometer) the other three are for general illumination.
Twist out and replace til your hearts content.
Note: LED's only work one way, once replaced, switch the light on and check they are working before refixing!
Re-fitting is the reverse of removing. It is really simple.
Before:
After:
The finished product:
Hope it helps.
 Post Posted: 24 Nov 2011, 10:31
i see they repainted the needles also.
nice touch
made steeekeee
 Post Posted: 24 Nov 2011, 11:31
:duim: you are awesome lol thanks a lot man really appreciate it.
Current
2008 Opel Corsa C UTE 1.4i
2x Pioneer Champion Series 10" DVC's
1x XTC 5000watt Monoblock
123db
2000 Opel Corsa B 1.4i
EX1997 VW Citi Golf (1.6i Polo Conversion)
1991 VW Citi Golf 1.3
 Post Posted: 03 Apr 2014, 16:29
howzit peeples. I had to replace my odometer light (Osram 12/1.2). This "how to" was a great help, but taking the cover off the display unit was frustrating to say the least. so I took some photos of how I put it back in... taking it out would be in the reverse order
File comment: place over top gauge cover
File comment: gently force edge under steering wheel
File comment: slip the cover down
File comment: line up the edges and secure screws
'09 Opel Corsa Utility 1.4 Club
 Post Posted: 03 Apr 2014, 18:44
Can someone pleeeeeaaase do this for my Corsa B? Wanna change it to white but scared I'm gonna break something :lol:
Daily: 2005 Corsa Lite
Jason Clifton Photography
 Post Posted: 03 Apr 2014, 20:22
Can someone please enlighten me where I can get those bulbs but in LED. . . .I have been battling to find them since 2009
Daily Ride: 1998 VW Polo 1.6i Classic
Sunday Cruiser: 2006 Opel Corsa 1.4i Sport
Cherished Ride: 1989 Toyota Conquest 1.3
Sunday Toy: 1998 Suzuki RF400R
ex Ride: 1989 BMW 320i
 Post Posted: 04 Apr 2014, 07:19
Best place would be a company called CrazyLed.
They are based in the UK.
You can order them off their website for 20 pounds
 Post Posted: 04 Apr 2014, 07:58
Contact Sugan at Violet Electronics in JHB
He will courier
@Jason - My mechanic can do it
I ALWAYS break something so he does all those stuff for me :D
We had to change the heater control bulb on my fiance's Corsa B a few months ago
What a mission I tell you!! Really! I would have probably broke the whole dash if I had to do it :oops:
 Post Posted: 05 Apr 2014, 09:28
well I was thinking of importing the whole set but im very sceptical about importing stuff. I dont know if you have imported already and can put my mind at rest
He will courier
Violet Electronics was my next option cause they are at least in SA
 Post Posted: 24 Apr 2016, 16:49
what a great tutorial for the diy.reminds me i have a few for you guys
it takes a nation of millions to hold us back-Public enemy 1987
 Post Posted: 25 Apr 2016, 11:14
It was a biatch getting my Coupe's cluster back into the white connector. But it's such a nice thing to do if you're sick of amber.
