Chezzy R
Posted: 05 Sep 2013, 19:56 |
Joined: 05 Sep 2013, 10:09 Posts: 8 Location: Bay View Strandfontein
Hi i have a 2001 Corsa B. Any advise on we're or how the best place will be to earth my Amps. Coz this buzzing is driving me Insane when I drive or when the car is idling.
Koperdraad
Posted: 05 Sep 2013, 22:03 |
Pioneer deck?
_________________  10 Ford Bantam XLT 1.6 i EX: 04 Opel Corsa B 1.4 i SOLD Very Sad EX: 95 Golf MK1 1.3 SOLD
Posted: 07 Sep 2013, 10:23 |
Koperdraad wrote: Pioneer deck? Only happens if they connected the wrong wires 1st and blew the IC. If installed correctly it wont do that.
Chezzy R
Posted: 07 Sep 2013, 11:49 |
there is sound I hear da music,if the volumes above 35+ I don't hear the buzzing. Its only ther when I drive.
high-knee
Posted: 10 Sep 2013, 21:29 |
Joined: 09 Sep 2013, 20:09 Posts: 41 Location: In some car's boot fixing the mess some oke made to his sound system!!!
Does the pitch of the sound vary with the engine rpm? cause then it might be the rc cables picking up the magnetic fields from your amp's power cable. by rerouting the rc cables it might solve the problem or so i've read on some of the forums. i have such a sound in my corsa c, i have yet to reroute the cables as i havent had time. previously i used a hi-lo coverter with my standard deck then i didnt have that problem. its only after laying the rc's i had the sound.
_________________ 2003 Corsa Classic 1.6 Elegance Engine:Stock Sound: Headunit - Alpine CDE-9874E Front - Standard Mids with some tweeters Amp - MTX Audio Thunder 81000D monoblock Sub - Audison Voce AV 12
Chezzy R
Posted: 10 Sep 2013, 21:38 |
Thanks high-knee will change this sucker the weekend. Thanks allot
opel cali
Posted: 10 Sep 2013, 21:41 |
Joined: 03 Sep 2012, 21:26 Posts: 314 Location: Durban
if it is that k@k engine noise.. u can earth the rca cable to the deck itself it will go away, which is far easier that re routing the cables itself
_________________ 1992 Opel Calibra 2012 Hyundai i30 Ex 200ie
high-knee
Posted: 10 Sep 2013, 21:47 |
what you mean by earth the rc's to the deck opel cali? cause it will save a lot of time if there's another way...
Chezzy R
Posted: 10 Sep 2013, 21:48 |
Thanks guys for all the info and replys. Ill try the easy ones 1st. I do appreciate it allot.
opel cali
Posted: 11 Sep 2013, 20:07 |
LOL maybe my lingo isnt correct, basically u a short piece of twinflex or ordinary single piece of speaker cord okay. there are plenty of screws on your deck, unscrew 1, attach 1 piece of the cable to that screw and screw it back. the other end of the cable tie it to the metal bit of the rca before plugging it into the back of your deck.
look dont get me wrong its a bit of a "backyard" job, but it has worked for me. I have also done the whole relaying of cables to get rid of the noise and that works as well.
Chezzy R
Posted: 11 Sep 2013, 20:13 |
Thanks Ocali that makes a bit more sense.
high-knee
Posted: 11 Sep 2013, 21:53 |
Thanks Cali, will be sure to try it as well for now, and later relay the wires, Koperdraad wrote: Pioneer deck? Koperdraad your setup looks really neat, what subs/amps you running? Did you meter it?
high-knee
Posted: 11 Sep 2013, 21:54 |
Sorry for hijacking your thread Chezzy lol
opel cali
Posted: 11 Sep 2013, 23:11 |
no probs gents hope all works out
Chezzy R
Posted: 11 Sep 2013, 23:39 |
Buzy weekend ahead. Thumbs Up guys
Posted: 12 Sep 2013, 11:41 |
opel cali wrote: LOL maybe my lingo isnt correct, basically u a short piece of twinflex or ordinary single piece of speaker cord okay. there are plenty of screws on your deck, unscrew 1, attach 1 piece of the cable to that screw and screw it back. the other end of the cable tie it to the metal bit of the rca before plugging it into the back of your deck.
look dont get me wrong its a bit of a "backyard" job, but it has worked for me. I have also done the whole relaying of cables to get rid of the noise and that works as well. This works if it is an IC that was blown but in the end its best to see if you can rather have the IC replaced. The laying of the cables will work if the IC isn't blown.I deally, you want your power cable running on the one side of the car and RCA's running down the other side.
opel cali
Posted: 12 Sep 2013, 12:35 |
DJ7 wrote: opel cali wrote: LOL maybe my lingo isnt correct, basically u a short piece of twinflex or ordinary single piece of speaker cord okay. there are plenty of screws on your deck, unscrew 1, attach 1 piece of the cable to that screw and screw it back. the other end of the cable tie it to the metal bit of the rca before plugging it into the back of your deck.
look dont get me wrong its a bit of a "backyard" job, but it has worked for me. I have also done the whole relaying of cables to get rid of the noise and that works as well. This works if it is an IC that was blown but in the end its best to see if you can rather have the IC replaced. The laying of the cables will work if the IC isn't blown.I deally, you want your power cable running on the one side of the car and RCA's running down the other side. o great, i didnt know that.. hmm looks like i have a problem then..
Posted: 12 Sep 2013, 14:49 |
opel cali wrote: DJ7 wrote: opel cali wrote: LOL maybe my lingo isnt correct, basically u a short piece of twinflex or ordinary single piece of speaker cord okay. there are plenty of screws on your deck, unscrew 1, attach 1 piece of the cable to that screw and screw it back. the other end of the cable tie it to the metal bit of the rca before plugging it into the back of your deck.
look dont get me wrong its a bit of a "backyard" job, but it has worked for me. I have also done the whole relaying of cables to get rid of the noise and that works as well. This works if it is an IC that was blown but in the end its best to see if you can rather have the IC replaced. The laying of the cables will work if the IC isn't blown.I deally, you want your power cable running on the one side of the car and RCA's running down the other side. o great, i didnt know that.. hmm looks like i have a problem then..  That work around worked for me for just over a year and then it didn't anymore.
high-knee
Posted: 12 Sep 2013, 18:34 |
Re-routed the rc cables on the driver side, power cable running passenger side, no more alternator buzzing.  Thanks guys
Vitesh
Posted: 17 Sep 2013, 10:37 |
Joined: 06 Oct 2011, 16:04 Posts: 669 Location: Cape Town
Alternator whine is i think any car sound enthusiasts worst nightmare!
I have done everything and still got whine and scratch when i press the pedal... some say its due to the turbo thats causing electrical interference, i also sanded the ground points inside and outside the car, used a stainless steel bolt which goes through the bolt hole for the rear seat so it is definitely in the chasis. the power cable and rca's are separate too... just gave up
_________________ ____________________________________
2010 Corsa D 1.6 119Kw Turbo Sport 2010 Corsa D 1.4 Sport 80kw
