Board index » General Chat » Experiences
Post new topic Reply to topic  [ 17 posts ]
 Post Posted: 18 Oct 2012, 13:13
So in June of this year I did a major service on my car at Tobias Motors. 2 weeks ago I noticed while I was driving on the open road my heat gauge showed cold (blue) after showing +/-90degrees 5minutes before. I decided to replace the thermostat yesterday. I took off the old one and I was shocked to find that it was clogged with gasket maker on the inside. It’s almost as if they used half a tube of gasket maker to fit a thermostat. I’m not a mechanic but I know that’s not how its suppose to work.
 Post Posted: 18 Oct 2012, 13:29
This was my Quote 07/06/2012
Quote:
Qty Description Unit Price TOTAL
205 000km Service
Replace engine oil and filter
Replace fuel filter
Replace air filter
Replace spark plugs, replace sump plug washer R 697.00
Clean and adjust brakes all round
Top up all fluid levels
Check all lights
Check all over
Add anti-freeze to cooling system R 80.00
Engine Cleaner R 28.00
Sundries R 40.00
Replace timing belt and fanbelt,tensioner and idlers R 1,275.00
Replace waterpump R 350.00
Replace thermostat R 302.00
Replace front pads R 471.00
Replace rear brake discs R 431.00
Clean out idle valve and throttle body
SubTotal R 3,674.00
Labour R 2,475.00
TOTAL R 6,149.00
 Post Posted: 18 Oct 2012, 13:36
205 000km Service
Replace fuel filter
Replace air filter
Check all lights
Check all over
Sundries R 40.00
SubTotal R 3,674.00
Labour R 2,475.00
TOTAL R 6,149.00
:wtf!: :wtf!: :wtf!: :wtf!: :wtf!: :wtf!: :wtf!: :wtf!: :wtf!:
KS Motorsport :woot:
:OpelLogo: :Calibra: 0kw 0Nm
 Post Posted: 18 Oct 2012, 13:41
True :wtf!:
Im never going back there again. If I can do it myself, then Im gonna do it myself other than that, then KSD will be good for everything else I cant do.
 Post Posted: 18 Oct 2012, 13:44
R6k??? Donner!!
Opel Club Cape Town Chairman
My Ridez
Opel Kadett Superboss Image 16vS 20XE
Toyota Prado 3.4 V6 VX
Hyundai GetzR Open-filter-box 16v
Ex Ridez
2000 Opel Corsa B Image 1.8 16v Image conversion
1991 Opel Cub 1.6i 8v c16ne conversion
 Post Posted: 18 Oct 2012, 13:49
Thats enough for money to do your head over :ninja:
 Post Posted: 18 Oct 2012, 13:57
I can get a 8v motor that has been serviced for that price. Guys..men..its really easy to do most sevices,brakes,c.v joints anythng on your cars,6k,damet,i do everything myself,i cant stamp my book though,i'd be happy to service a car for R150 if you buy your own parts,with garentee. Or teach you to d.i.y for R30 lol
 Post Posted: 18 Oct 2012, 14:07
I wouldnt mind paying you if you showed me how to DIY, It actually frustrates me because I dont know where to scratch or change stuff on the car with regards to the motor.
 Post Posted: 18 Oct 2012, 14:13
WezGSI wrote:
R6k??? Donner!!
:oops: I didnt know at the time, I learned the hard way. Thats why Im sharing the experience so that others dont make the same mistake.
 Post Posted: 18 Oct 2012, 15:01
i redid my sub assembly and head for 6600 incl labour . . jisalaaaaaaaaaik
 Post Posted: 18 Oct 2012, 15:20
Yeah man! how can they charge 500 just for front brakes? WTF
My Ride:
94 Kadett 200tS Under construction
07 Corsa UTE
 Post Posted: 18 Oct 2012, 15:29
Well
I know i posted some time back I had used Tobias motors to service my car and attend to some issues, and at the time I thought i got a good deal.
Just before I sold my car, i realised that they had charged around 3k, but had done very little.
I had a misfiring issue, and they replaced all 4 leads with cheap no-name brand leads.
There was a receipt for wheel bearings done, but less than 10 000km later the bearings needed to be replaced again
They were asked to inspect the fuel lines and tank because i was getting heavy fuel consumption : Never happened. The next mechy I used sorted this out.
They diagnosed a noise coming from the front suspension as me needing a new gearbox.
All I actually needed was a new front left hub.
Please MTV.. Pimp My Ride
 Post Posted: 18 Oct 2012, 15:41
That is what they cost. I got a quote for R480 for ATE and R550 for Ferodo's about 6 months ago for front pads for my IS at Midas, just the pads. R128 for Moto-part
6K - Wow.
 Post Posted: 18 Oct 2012, 15:47
if it includes parts then it fine but just labour? I dont know...
My Ride:
07 Corsa UTE
 Post Posted: 18 Oct 2012, 16:48
New engine C20NE is 4500
Antifreeze to cooling system is easy on a 200is lol drain water by main pipe of radi and take off water cap and throw in anti freeze done. R25 for antifreeze and 10min job
 Post Posted: 22 Oct 2012, 08:19
chez was this on the 200is or the other car i saw you with?
you are in the blackheath area right... you have my number. next time call me when you need something done and i will send you to a mechanic close to you.
i hate when i see people getting ripped off like this. i remember posting something similar a few months ago where my TL got quoted over 5k for a service and replacing a coil pack on her corsa. after speaking to me she called the guy back and he quoted her 3k because she had a bit of knowledge. eventually i had a mechanic drive out and do everything she needed and more for 1.5k
 Post Posted: 22 Oct 2012, 09:29
I got your digits I will definitely remember that. That service was done on the Astra G 1.6. The kadett I usually service myself. I thought I’ll give the Astra to the professionals to look after. Anyway thanks 8 valves.
