Lots of people having issues with image sizes. So here's a quick and easy way to resize images on a Windows machine.
Download and install Image Resizer tool from Microsoft.
http://download.microsoft.com/download/ ... ySetup.exeOnce installed, all you have to do is:
1. Select the pics (shift+click or Ctrl+click or Ctrl+A) you wish to resize.
2. Right click on your selection
3. Select your size from the "Resize Pictures" dialog box.
4. Click "OK"
The files are saved as copies, alternatively, click "Advanced" and select to overwrite original files.
If you're in the My Pictures folder then you also get the "Rotate Clockwise" and "Rotate CounterClockwise" on the right-click menu. Change the orientation of your Pic with two clicks of the button
