Post new topic Reply to topic  [ 10 posts ]
 Post Posted: 20 May 2019, 00:13
Hey guys,
I am looking to start building a portfolio of experience in building custom induction systems that is practical in theory– improves air intake velocity speed and density – and practical in design – easy to install/uninstall - with a top quality finish.
I did this set up for the OEM look but with the best possible performance. Here’s what I did to it.
Air box – Completely redesigned the bottom of the filter housing by closing off a section inside and adding a second cold air feed (50mm) for a smoother air flow through the air box. I removed the snorkel from the lid, filled away some of the grooves inside the lid for smoother airflow and on the outside for a unique look. The entire airbox was sanded down to a smooth finish, all rough edges and corners were smoothed.
Rubber air intake tube with IAT sensor – no changes by a good clean.
Throttle body – I stripped it down for a thorough clean. The flange was filled in a shape of a trumpet to open it from 57mm to 63mm. The rest of the bore was left standard size with 45mm butterfly. The inside including butterfly was polished – starting at 180grit and finishing at 320grit. The TPS was recalibrated using a voltmeter (0.6v at idle with butterfly closed and 4.6v at WOT)
All chrome parts were cleaned and polished, and the airbox and throttle was finished in high heat Matt black paint. I sold this with the K&N panel filter (had an old while laying around) to my buddy with a Corsa lite 1.4. It gave a noticeable difference in acceleration through the gears with a nice induction roar, purely because of the air flowing faster.
Hope you like my work! More pictures to follow
2002 Opel Corsa Gsi ltd 1.6
Custom cold air induction system
Polished throttle body (53mm)
OEM exhaust manifold
50mm stainless steel straight through exhaust system
Smash & grab tint
Webasto tilt and slide (factory fitted)
Style inspired by Opel Motorsports
 Post Posted: 20 May 2019, 07:49
Looks neat. Well done
Price range? You planning on mass production?
 Post Posted: 20 May 2019, 19:42
Pics of the air box modifications.
File comment: Redesigned filter house. The left side of the airbox was closed. I did this for two main reason:
1. To eliminate disruption of air flow in the air box.
2. To suck more air through the cold air feeds by reducing the space inside the air box.
File comment: Second cold air feed - 50mm diameter - fitted at the bottom left hand side of the airbox.
File comment: Before (top) and after (bottom)
Smash & grab tint
 Post Posted: 20 May 2019, 19:50
Pics of work done on the throttle body
File comment: Another two more coats
File comment: First two coats
File comment: Preparation is key
File comment: Ready to be sprayed
File comment: Shaped the flange to increase the radius of the opening
Smash & grab tint
 Post Posted: 20 May 2019, 19:59
Throttle body - show case ready
Smash & grab tint
 Post Posted: 20 May 2019, 20:13
I sold this set up for R750. The airbox and filter was laying around in my garage and I wanted to make the most of my money back from the filter.
I'm not looking to mass produce this one, I but I do have a cold air intake system design for Corsa B 1.6 that I could look at mass producing. I'll post some pics the moment I have a final design.
This is post is show my workmanship and design theory I apply when it comes to improving air velocity speed and density for anyone who is looking for someone to build or improve an intake system.
Smash & grab tint
 Post Posted: 21 May 2019, 09:38
 Post Posted: 24 May 2019, 10:06
Would be interesting to see dyno results on the same day with the same car and using this and the standard stuff.
 Post Posted: 25 May 2019, 11:40
There wouldn't be much of a difference in the kw curve because the throttle still only let's in so much air. There should be a difference in the torque curve as air will flow faster in to the cylinders, increasing acceleration.
But it would be interesting to see what difference this set up would make on a dyno.
Smash & grab tint
 Post Posted: 25 May 2019, 11:57
And as with all great designs.... It's starts with a drawing!
Smash & grab tint
