Board index » PC/Console Related » PC
 Post Posted: 03 Oct 2010, 23:11
sup guys figured maybe one of you can help me
i have Samsung 923NW 17" or a 19" Widescreen, running screen resolultion at 1440x900 60Hertz RR, Nvidia 9600GT, Windows 7 64bit.
i noticed that my desktop is positioned a few centremeters down, i cant see the time properly or my taskbar icons, i tried setting the Horizontal Position on monitor even auto adjusted but it stays that way, played with the RR set it to 70hertz and changed resolution when i set to 1280x1024 then its perfect but everything is stretched, i updated to latest nvidia drivers ...
Driver date: 2010/07/09
Driver version: 8.17.12.5896
258.96_desktop_win7_winvista_64bit_english_whql
games play fine, just my desktop is shifted a few centremeters down, can only see the tip of the icons in the taskbar, and at the top there a thick black area of nothing tried adjusting it in display properties but then when i play games the h-position is too far up, nothing is workin so im running out of ideas, anyone know what the problem could be any ideas will be appreciated ?
thnx
soon 200SX S13
 Post Posted: 03 Oct 2010, 23:54
There should be an auto adjust button some where on the monitor.
Press it and it should adjust the picture correctly :)
2013 Polo GTI
ex: 2009 Fiesta ST190
 Post Posted: 04 Oct 2010, 20:08
LOL you know how much times i pressed that button, shot it, it worked if it wasnt for you i would never have pressed it again :duim:
soon 200SX S13
 Post Posted: 04 Oct 2010, 20:20
lol
 Post Posted: 11 Apr 2011, 08:36
You should go to the Nvidea application, advances options. Look for screen positioning, normally a square with arrows pointing outwards. You may need to create a profile or just edit the current one and then manually adjust the screen position and size.
Even if you are on the right track, you will get run over if you just sit there!!!
