 Post subject: Astra G Central locking
 Post Posted: 24 May 2013, 11:39
Guys need some help please,
My central locking does not want to work, since lastnight i notice while driving that the red light on the key stays on so then i thought ima wait until i get home, took the key out the ignition still on, then back into ignition and did the reset central locking method by holding in the top button for a few seconds did'nt work, took it out and locked the car manually, light stays on, im in the house and light still on :think: woke up this morning the phokin! light still on and now im at work typing this hoping ima get some help while this LIGHT IS STILL ON! help please :veryvery:
Ex cars: 1st. 1974 VW beetle
2nd Opel Kadett 1.6 GSE
3rd Opel Kadett 1.8 8v GSi
4th Opel Kadett 2l 8v GSi (red)
5th OPel Kadett 2l 8v GSi (black)
6th Opel Astra 1.6 CDE
Current car: 2003 Astra Coupe Turbo
Topic moved to 'Interior'
 Post Posted: 24 May 2013, 13:04
Start with taking it apart and resetting it by removing the battery + check if anything has broken that keeps one of the buttons pressed down
 Post Posted: 24 May 2013, 13:16
I took out the battery already, will check it out. Thanks Gouraami
 Post Posted: 24 May 2013, 15:07
:thumbup: :thumbup: Gouraami you the man, thanks boet
some kind of pin suppressing onto the circuit board, just lifted it slightly then the light switched off and then did ignition reset move. WORKED! :woot:
 Post Posted: 05 Jun 2013, 16:24
:duim: Glad you are sorted man
