09 Dec 2011, 15:41
09 Dec 2011, 15:49
09 Dec 2011, 16:12
07 Mar 2012, 01:32
07 Mar 2012, 07:55
Nemesis wrote:2nd time i see you post this crispy and I have to correct you. you right in adding the fuses on the amp and multiplying but rather use 13.8v as 14.4v isn't always achieved even at idle. so your formula now reads for eg. on a 4ch class ab amp
2x30amp fuses x 13.8 = 828 rms (not possible) but lets go further...
take the 828 rms x 0.5 as power is lost due to heat (hence your amp getting warm when playing it) and you end up with 414rms
divide that by the 4 channels and you end up with 103.5rms per channel.
class ab amps arent very efficient due to it losing power through heat, therefore monoblocs (class d amps) tend to run cooler but has a higher distortion level and are therefore mainly used for subs. calculation for a monobloc you would just have to multiply by 0.9 (instead of 0.5) and you wouldnt have to divide by anything as there is only 1 channel.
this is a very useful calculation when shopping for amps especialy when "unbranded" products use PMPO/max power ratings on there amps. please dont change the fuses on your amp to something higher and then do the calculation. you are only going to fool yourself.
enjoy
30 Apr 2012, 14:27
enjoy
16 Jul 2014, 22:17
18 Jul 2014, 01:00
18 Jul 2014, 11:50
21 Jul 2014, 11:45
21 Jul 2014, 19:15
